RCDLR Replacement and programming
Old Aug 20, 2023 | 08:39 PM
Originally Posted by Oldblue
But then again it could be the RCDLR needs reprogrammed, that requires a scan tool like a Tech II
If it was a 2008 and we were talking about the TPMS that might be true but we cleared that part up a few months ago. That is a problem with not starting a new thread for a new problem and not hijacking threads
Old Aug 20, 2023 | 08:47 PM
BigT's Avatar
Thanks for all the great information. I took a quick look at Dorman and it looks like there may be a solution there. I'll dig deaper tomorrow. I had the other original fob that came with the car. My wife wore it out pretty good and it did not work. just for the fun of it I took the guts out of it and put it in my fob and it now works. The combination of her guts and my case has at least temporarily solved the problem.
Old Aug 20, 2023 | 08:51 PM
BigT's Avatar
Sorry about hijacking this thread but it wasn't very old and it was going in the exact direction I needed to go so I tagged on. It looked like the OP had gotten what he needed and was gone from the thread.
I really appreciate the help I got.
Old Aug 21, 2023 | 07:46 AM
New keypads are cheap look on ebay. Intermittent means keypad not circuit board. If you change batteries; carefully push the old one out, the battery cage is barely held on by solder.
Old Apr 24, 2026 | 01:01 AM
HHR SS 3M...'s Avatar
I recently replaced all my TPMS SENSORS & bought a RESET TOOL from EBAY, the traditional way of using the DIC wouldn't work when trying to reset = the TPMS RESET TOOL i got from EBAY worked, & it was a super quick & easy process...
Old Apr 24, 2026 | 07:10 AM
  #26
The EL 50448 device works well for the relearn process.
ROB123
Sep 18, 2022 10:19 AM
bhs
May 7, 2015 03:44 PM
Finch106
Jun 6, 2012 09:48 AM
Musky
Jan 24, 2011 04:14 PM
