Stalling Issue
Old Dec 29, 2020 | 10:22 PM
ibenzawla's Avatar
Originally Posted by JGN62
I have the same year and model. Last month the car started becoming hard to start. No codes relating to fuel showed up. I tested spark, compression, fuel pressure,electrical circuits because my engine eventually would not start. As mentioned no codes. After much consideration, I replaced the High pressure fuel pump. Problem solved.
Unrelated, but after checking the timing chain, it was loose and the plastic guide was broken. All repaired and running like a Champ! I was surprised that a timing chain was bad at 140000kms.
Will consider that. For now I want to start with the easier stuff but yes the fuel pump since to be problematic. Amazing car. As a new owner I'm truly impressed so far. Impressive fuel MPG. Great performance. The interior styling makes it feel like a luxury car. Best car seats I've sat on so far.
Old Jan 9, 2021 | 11:36 AM
ibenzawla's Avatar
Idle Control Valve?
Hi again so I have a quick question. Does the HHR SS have Idle Control Valve or something similar? I was thinking about replacing it since the issue only happens after cold start. I have searched but unable to see any info about it.
Old Jan 9, 2021 | 12:50 PM
No, the MAF monitors that
Old Jan 9, 2021 | 04:25 PM
ibenzawla's Avatar
Okay thanks a lot.
Old Jan 11, 2021 | 02:03 PM
Cokeybill's Avatar
Luxury car?? I owned an '08 HHR SS with GMPP tune. It was far from a luxury car. I bought a Cadillac XT5 after the SS(2019) and know that the Caddy is luxury. The SS is a great performance car with a tune...but far from luxury. Good luck with the SS, I regret selling mine. I should have kept it and stored it with 37,000 miles on it.
Tyler Harvey
57
Aug 23, 2012 11:50 AM
Tyler Harvey
Jun 23, 2011 03:21 PM
Don06
Dec 1, 2010 09:58 PM
wraunch
May 1, 2009 12:29 PM
Frozenspokes
Jan 19, 2009 07:44 PM
