Stumble on start up
Old May 15, 2012 | 04:18 PM
Tyler Harvey's Avatar
Originally Posted by Breadfan
Hmm. I had similar issues when I was tuning for a different intake. Before I was tuned the car would skew the long term fuel trims to accomodate the different intake. These remembered long term fuel trims would cause the car to stumble on cold start until the active short term trims kicked in to adjust in real time. Perhaps pulling the fuse for the computer to reset it now that you have swapped back to stock would help? The surging at part throttle seems to suggest something else though. Maybe bad purge solenoid? Maybe weak bypass valve? Hopefully, someone more expert than me can jump in here.
Which fuse do you recommend pulling Breadfan?
Old May 15, 2012 | 04:45 PM
Breadfan's Avatar
I believe it is #41 under the hood. If you aren't sure, disconnecting the battery for about 30 seconds will work too.
Old May 15, 2012 | 04:51 PM
Thanks.
Old May 15, 2012 | 04:59 PM
whitelightnin's Avatar
mine was real hard to crank a while back and once it cranked it ran real rough for a little, cleared up as soon as i started driving. i had stuck valves and a fuel injector was shorting out.
FatTireBiker
2.2L Performance Tech
Jun 9, 2014 01:56 PM
roofer1976
Jan 4, 2014 02:09 PM
Crash06
May 8, 2010 08:27 PM
Marcruger
Oct 5, 2009 06:32 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
