Surging when driving normal
Old Jun 7, 2010 | 08:19 PM
  #91
redradt25's Avatar
I find that I really don't hear my BOV unless I really 'get on it'. Do you hear it now know matter what, and did you hear yours before the new turbo? Two questions here....please answer for me. Really trying to narrow down problem. Thanks a bunch!!!!
Old Jun 10, 2010 | 09:38 AM
  #92
DMarotta's Avatar
Do you hear it now know matter what - Yes and no. It is clearly heard when releasing a WOT, considering that I am frequently WOT I would say yes no matter what.
Did you hear yours before the new turbo? Yes, however the tone has changed to a lower pitched "pushss" that a higher pitch "pishhh"
Old Jun 10, 2010 | 10:29 AM
  #93
redradt25's Avatar
Thanks guy. All the info I can get, the better. Appreciate you answer.
Old Jun 15, 2010 | 05:54 PM
  #94
redradt25's Avatar
Angry Today at dealer again.
Well, my 'SS' is back at the dealer. This is the fourth time. First time, really wasn't bad enough I guess; they couldn't find anything. Second time, tech rode with me (him driving) an I got a "HOLY S%^T" out of him. He said, "okay, we deff. have a problem." Finally, something to go on. Top t-map sensor for Stage-1 was replaced. This didn't do it. The last time, ECM was changed. Guess what, its back for the same problem. Still surging and 'shuttering ' down the highway. So, I think I convinced him to solder wires and check by-pass valve (hope they changed turbo since bypass comes with new turbo only) .
Old Jun 20, 2010 | 11:39 AM
  #95
redradt25's Avatar
Think I am on to something; this forum is awesome. I am just about convinced my By-pass spring is bad and the diaphragm is not working properly causing by-pass leaks, boost surging,bogging, and hesitations. I ordered a spring, and will give you guys and update. Thanks to the BOV thread!!!!!!
Old Jun 20, 2010 | 01:02 PM
  #96
Lars on Live's Avatar
Let me know what you find
mine does the same thing.
Old Jun 21, 2010 | 08:54 AM
  #97
camaro98z28's Avatar
Soldering the wires fixed mine.
Old Jun 21, 2010 | 06:45 PM
  #98
JimVette1's Avatar
Sorry I didn't read every single post ( ten pages of them) so if someone else has offered this fix,sorry.
My story is about the same as most here. The surging first was noticed slightly around 35 to 40 MPH.
Not all the time, just enough to be an annoyance.
Then one night I punched it getting onto the highway and Scream went the turbo ! Very loud noise and no turbo boost (5 pounds only max.)
Next day everything was working fine, go figure? But the surge started getting worse.
My Solution:
My son put our scanner (AutoXray EZScan-5000) on the old girl and told me the O2 Sensor was bad. O2 sensors are supposed to cross-count and mine wasn't do that. Hung around .5MV without moving much at all.
Checking my Air/Flow gauge: It was all over the map, with violent mood swings everywhere.
The ECM had no way of knowing what air / fuel mixture to administer.
The Fix:
However getting the dealership to listen to the customer was a different story.
Short story, after three trips and me telling them all three times it was the O2 Sensor, it finally threw a code and they replaced, YES, the O2 sensor.
Not a single surge or stutter since getting it back.
I'm sure there are many other reasons for the surging and stuttering being reported here. This is my solution, and it worked so far.
FYI: 2009 HHR/SS Turbo Stage 1 kit , 16K miles
Old Jun 22, 2010 | 12:11 AM
  #99
DMarotta's Avatar
My turbo died after the stage upgrade, it took a long time but they finally replaced it.
Old Jun 22, 2010 | 08:09 AM
  #100
jerSSey HHR's Avatar
Back to the original thread title - my SS surges quite often during my normal driving.
