Turbo coolant line.
Turbo coolant line.
So I am installing new timing set and clutch. It has taken me some time to get to this point after discovering that my issue was the chain that drives the water pump had broke. I am currently putting things back together and cannot find a bunch of the bolts which isn’t an issue for the most part. However the banjo bolt for the coolant line is one of those missing bolts does anyone have any part numbers or advice on where to find this?
Part Number: 11561875
2.0 LITER TURBO 2011-2013. 2.0 LITER TURBO LUBRICATION & COOLING LINES/HOSES. Turbocharger Coolant Line Bolt. Turbocharger Oil Line Bolt. Coolant. Oil. Cooling pipe. Feed. Return. Included with: Feed line, Return & feed cooling pipe, Return line.
Fits HHR (2008 - 2010)
Available online,
https://www.gmpartsdirect.com/oem-pa...-bolt-11561875
And don’t forget the gaskets GM part number 12612817
https://www.gmpartsdirect.com/oem-pa...asket-12612817
SSROADSTER
43
Mar 7, 2022 08:46 PM
