Guess that Wheel and Tire size
Old Jul 25, 2021 | 05:05 PM
SkullWerkz's Avatar
I found the car on marketplace, messaged them and asked what it was running, I was told they were 215/65r16s, from what I was reading on here 65s wouldnt fit, max would be 60s because of the spring perch. Tried to message again to see if that was correct but got no reply.
I like the look and would like to do something like that with my 08 (picked up a couple years ago for only 300$) but maybe in a 15" wheel, I like the big tire look over the 215/55 I have on it now, I need new tires anyways.
Old Jul 25, 2021 | 05:33 PM
They could very well be 215/65/16. Although that size wouldn't work on stock HHR rims, they could work on the aftermarket rims in the picture. With the skinnier 65 series tire and aftermarket rims w/offset that puts the tire farther out in the wheelwell, it may clear the spring perch. I would just worry about the fronts scrapping on the wheelwell liner when turning.
Old Jul 25, 2021 | 06:07 PM
Those rims appear to be Wheel Vintques, they have a 35 mm offset so an extra 7 mm of clearance over the stock 42 mm steel rims, so the 65’s should fit.
It doesn’t show here but the tires are further out to the fender openings, here on Oldblue, with the WV rally rims
Here’s Oldblue with stock rims and same tires as the other photo
Old Jul 25, 2021 | 06:21 PM
SkullWerkz's Avatar
Oh right on, guess i didnt think about that, Thanks for the info guys!
KyS10
Tires & Wheels
Jun 25, 2013 08:08 PM
badflt
May 5, 2012 04:04 PM
barfan1
Tires & Wheels
49
Jan 2, 2012 10:45 PM
Sno White
Tires & Wheels
Oct 30, 2010 10:07 AM
Laco
Tires & Wheels
Dec 29, 2009 12:22 AM
