Replacement wheel noise
Old Apr 5, 2012 | 07:45 AM
A couple things spring to mind. Bar sway bar bushings, bad strut mounts, or a bad lower control arm bushing.
You need to get it in the air, or up on good jack stands and look over the suspension components carefully.
Old Apr 5, 2012 | 11:07 AM
Doc brown's Avatar
I was thinking along the same lines. From his description, its not likely to be bad strut mounts or sway bar bushings. But a bad control arm bushing will can cause the tires to howl with a sound like a bad bearing. Some tire brands/tread patterns are more susceptible to this than others.
Old Apr 7, 2012 | 07:22 AM
pmarth's Avatar
Thanks to all who gave advice. 843de suggested I crawl under the car and check everything, which a did and found a loose sway bar link. I tightened it up and noise is gone. It was just a coincidence that the noise started right after the new wheels and tires. I now do notice that the Goodyear Eagle GTs are noiser than stock, but that's fine.
Old Apr 7, 2012 | 08:25 AM
Glad you isolated the source of the noise, sometimes chasing down an odd sound can drive you just short of nuts.
Old Apr 7, 2012 | 10:44 AM
Originally Posted by pmarth
I took it in to Discount tire and they rebalanced the wheels and installed the missing hub rings. No change in the noise. It must be a coincidence, and the noise must be from the suspension. I had earlier replaced the sway bar link with Moogs and that got rid of the little noise I previously had, but this is much more and sounds like an old car with bad ball joints. Any ideas? Car has 46k on it.
Did you replace the tires just because you wanted new tires? The OE tires should have lasted into 70K. What I'm getting at is there may be something wrong if the tires wore out that fast, and the type of wear could aid in diagnosis.
Has anyone looked at the control arm bushings? the shocks & struts? Shocks & struts can go bad in 40K.
Old Apr 8, 2012 | 09:07 AM
pmarth's Avatar
I replaced the wheels and tires, because I wanted to get the wheels and didn't want to put the old tires back on. Just a personal preference. You're right the tires look like they would have lasted well beyond the 46k I have on the car. There was no abnormal wear. Thanks
ucadam
Oct 24, 2013 02:30 PM
hurst2001
100
Nov 11, 2012 06:49 AM
lectric
Tires & Wheels
7
Nov 14, 2011 10:51 PM
SStiglich
Sep 28, 2009 01:32 PM
Rotor
Sep 22, 2009 11:29 PM
