waited just a bit too long...
Old Jul 31, 2022 | 10:03 AM
jimvw's Avatar
My internet has been crazy today, not a cloud in the sky so WTF?? anyhow here is the pics
Old Jul 31, 2022 | 10:04 AM
jimvw's Avatar
I know the rims need some work, but it is a daily driver, about 500 miles a week...
Old Jul 31, 2022 | 11:04 AM
Nice! I wonder it those wheels would look either
A: gunmetal metallic?
B: matching body colour?
C: metallic silver?
the possibilities are endless, just sand them to get the scrapes and scratches feathered out .
Or the tedious job of sanding, polishing the aluminium to a brite finish.
Old Sep 15, 2022 | 01:29 AM
jimvw's Avatar
well, they didn't last long. driving home tonight I noticed a slight vibration, the inside edge of both front tires is worn past the the belts in the tires. Outer 95% look OK. rear are still like new. guess i need to find an alignment shop. Sway bar links were replaced as were the Lower Control arms on both sides. Shocks?? Guess I will be buying a pair of tires in the morning as the ones on there don't look safe.
Old Sep 15, 2022 | 08:59 AM
A problem that I experienced from replacing LCAs is a set I put on Altered the camber enough that my eye could tell. Close to a full degree. I believe that some of the castings are a little bit longer than they should be. The only way to adjust the camber is to add a camber kit, there is no factory installed adjustment. The only adjustment that can be made on a stock HHR front end is toe.
Sway bar does not affect alignment.
Old Sep 15, 2022 | 10:14 AM
jimvw's Avatar
so I am looking at replacing the LCa's with a better quality one?? I did get a cheaper one which in the not so long run was more expensive....
a closer look at the Amazon listing and there is a comment about them being too long and unable to adjust camber. Guess I will go with Rockauto Moog ones.
Old Sep 15, 2022 | 10:31 AM
You could get the alignment checked, some shops will do it for free.
Did you get aluminum LCAs, or steel?
Old Sep 15, 2022 | 11:53 AM
The camber kits are not too expensive, if you shop. I have seen the price range between $5 and $90 for the identical parts. It is an offset bolt with a off-center washers.
They look like this:
Old Sep 15, 2022 | 12:06 PM
jimvw's Avatar
the original ones on the car were aluminum, I used aluminum replacements, and the ones coming from Rockauto are Moog aluminum ones.
these are what is on right now, until the replacement Moogs arrive.
https://www.amazon.com/gp/product/B07Q8WT1BQ/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07Q8WT1BQ/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Old Sep 15, 2022 | 01:21 PM
Wow, for that price on Amazon, you could have had the GM Genuine from rockauto.com.
NM, I see now that the Amazon listing is for the pair.
