What is the MAX size tire and wheels for 06 HHR LT?
Old Oct 14, 2012 | 11:02 PM
Originally Posted by silverstreet
So keep Overall dimension same?
I'm assuming this means if I go with 17" wheels/rims with 215/50/17 tires in the front, and if I use 18" wheels/rims in the rear I would need to go shorter on the tire height to say something like 225/45/18 or whatever combo would make the actual tire/wheel height the same all the way around, in order for ABS to work properly?
Is this true? If so, my new question is do I even want my ABS active. I had my ABS out for 5 years on my 99 Bonneville and it never affected my ability to drive hard in summer months and safe in winter months. Or on the HRR is there another reason I'd want to keep my ABS active?
Yes, as I already posted this in post # 3 on this thread.. "Whatever size you use, TIRES should be the same height", or OD.. (reguardless of rim size
I like the ABS on mine.. You do what suits you about yours..
Also: A competent tire shop 'should' be helpful in selecting a proper offset..
Old Oct 19, 2012 | 10:49 PM
silverstreet's Avatar
Thanks Sleeper.
Old Oct 19, 2012 | 11:25 PM
IMPALADAKID's Avatar
Use this tool to figure tire size. You want to put in your stock size to the left, then you can play with tire sizes on the right. Just remember to keep your tire diameter the same, or you will have to tune to correct. Larger size will not affect abs or traction control, but will change speedometer, and odometer calibration. For instance, a 215/70/15 is the same diameter as a 255/50/17, but the other measurements are totally different.
http://www.miata.net/garage/tirecalc.html
Old Oct 19, 2012 | 11:53 PM
moonsign's Avatar
I'm running 255/40/18 Hankook v12's on my SS, with no clearance problems, and a whole bunch of needed traction. "Moon"
windsor837
Tires & Wheels
Jan 13, 2013 10:58 PM
simonb
Tires & Wheels
Nov 1, 2012 06:00 AM
JazzDad
Tires & Wheels
21
Oct 16, 2012 11:38 AM
1Bad06HHR
Tires & Wheels
12
Sep 28, 2011 10:29 PM
Davyo
Tires & Wheels
Aug 22, 2011 11:08 AM
