Winter tires/wheels - Feedback please
Old Oct 28, 2009 | 11:16 AM
esmarkey's Avatar
After last years winter, I think I am going to bite the bullet and get snows on the SS.
I am currently thinking of dropping down to a 16" X 7.5" wheel (Enkei FN18 gun metal +42) and the Blizzak WS-60 215/55R16's tires.
Has anyone had any experience with either the tires or wheels?
Also, is that size going to be very close to the stock 18" Michelins (P225/45R18)? I know it wont be as wide, but that should help in the snow.
Old Oct 28, 2009 | 11:49 AM
DLVRNIT's Avatar
If Putting a 16's On You Might Want to Go with 225 x 55 x 16" ! This Will Be a Closer Match to Your Current Tire Size in O.D. and Width !
Also Here's a Great Tire Size Chart for Reference:
http://www.rims-n-tires.com/rt_specs.jsp
Good Luck ,
Old Oct 28, 2009 | 12:13 PM
esmarkey's Avatar
That's a great tool, thanks DLVRNIT!
Does anyone know the stock width and offset of our SS wheels?
Old Oct 28, 2009 | 12:40 PM
DLVRNIT's Avatar
Geez ..... 7 1/2" Width and 42mm Off Set !
Good Luck ,
Old Oct 28, 2009 | 01:12 PM
esmarkey's Avatar
Thanks, Do you have to look this info up, or do you need to get a life , er ah... I mean do you actually remember this stuff?
Old Oct 28, 2009 | 01:42 PM
DLVRNIT's Avatar
I Gotta Life , I Need a Job ! I've Learned Alot On This Site So I Try and Remember as I Go Along, Especially What Not to Do !
Good Luck ,
txbass06's Avatar
A friend of mine has had a set of those wheels on his car for a while now. Aside from the damage he's done to them, they're still holding up good. The finish still looks like it did the first day he got them (if he'd ever clean them)
Old Oct 28, 2009 | 02:46 PM
fastsuv's Avatar
I have a 2006 1LT and have used the Bridgestone Blizzaks for 3 years. They are a great winter tire. I have used Blizzaks for the past 15 years on assorted vehicles.
You mentioned that you would use the 215/55R16 size (which is the factory tire size for the 16" tires). I am using 205/60R16 Blizzaks. The outside diameter is very close, but the tires are about $20 per tire cheaper for a total of $80 less on a set of 4. These prices are the Tire rack prices. It's also generally true that a narrower tire is better in snow.
Steve
Old Oct 28, 2009 | 03:34 PM
Father Azmodius's Avatar
I'm assuming you don't have the Brembos. If you do, you'll need an 18" wheel at least.
Old Oct 28, 2009 | 04:02 PM
ChevyMgr's Avatar
