Remote start, grind, clunk...car doesn't start
Old 03-06-2017, 04:36 PM
Sammy_SS's Avatar
I've experienced 3 times now where I go to remote start my 08 hhr ss (97k mi), engine starts to turn over then there's a loud grinding noise, engine shuts off then the engine light is on when I go to manually start it. First time got the code, said MAF sensor was bad, 2nd time "engine running rich at idle, without doing anything to the car, the next day the engine light went away. This time haven't gotten it checked yet but doesn't sound good. Anyone have this problem or know what it is?
Sammy_SS is offline
Old 03-06-2017, 04:52 PM
I suggest get that engine light checked, it could be dying battery.
Oldblue is offline
Old 03-06-2017, 08:57 PM
Technical Moderator
Since you didn't give the code numbers, I will guess that you should clean the MAF sensor. Both of those descriptions could be the same thing.
However, there is a good chance that the battery is going bad or one of the positive cables is loose, or a ground is loose, or the starter/solenoid is going bad.
donbrew is offline
Old 03-06-2017, 11:30 PM
Cokeybill's Avatar
That dying battery sounds about right.
Cokeybill is offline
Tyler Harvey
57
08-23-2012 11:50 AM
Jace1283
12-08-2009 06:13 AM
justamodeler
02-08-2009 03:44 AM
JJ_HHR
10-10-2008 04:45 PM
riverwind
08-05-2006 02:34 PM
Quick Reply: Remote start, grind, clunk...car doesn't start
