remote start not working
Old 06-01-2013, 08:48 AM
tntwolt's Avatar
Cool remote start not working
my remote start flashes the lights but will not start the car. whats up with that?
tntwolt is offline
Old 06-01-2013, 09:42 AM
Tyler Harvey's Avatar
Make sure nothing is obstructing the path and the top button needs to be held for two seconds. Check to make sure the rear hatch and hood are completely closed.
Tyler Harvey is offline
Old 06-01-2013, 10:12 AM
tntwolt's Avatar
has been doing it. so open doors etc block it? don`t get any thing on info center, (door/hatch adjar) the hood has something to do with it?
tntwolt is offline
Old 06-01-2013, 02:03 PM
Cokeybill's Avatar
Is your remote old, might need a new one. 2 of mine are almost finished. Only one will start my SS and that takes some long button holding. Might be a new $$ purchase.
Cokeybill is offline
Old 06-01-2013, 02:06 PM
JT's HHR's Avatar
Is your check engine light on? It won't start with the remote if it is.
JT's HHR is offline
Old 06-01-2013, 02:52 PM
You did do a search, before posting right?
From my 2011 Owner Manual.
The remote vehicle start feature will not operate if:
. The vehicle's key is in the ignition.
. The vehicle's hood is open
. The hazard warning flashers are on.
. There is an emission control system malfunction.
See Malfunction Indicator Lamp on page 4‑34.
. The engine coolant temperature is too high.
. The oil pressure is low.
. Two remote vehicle starts have already been
provided.
From Mitchel OnDemand:
The remote fob can become unsynchronized after 256 button presses while out of range of the car.
Read "butt locking" or, children having access.
Old 06-01-2013, 03:00 PM
My OM says 4 seconds.
Old 06-02-2013, 08:42 AM
tntwolt's Avatar
yeah, do have check engine light, cam pos soleniod.
tntwolt is offline
Old 06-02-2013, 10:30 AM
A fairly important point to "forget to mention".
voigtsga
04-25-2013 09:24 PM
xpeppyx
06-22-2010 07:46 AM
rewcolee1
08-05-2009 08:27 PM
HillsdaleHHR
02-21-2009 02:26 PM
SSROADSTER
01-23-2009 09:09 PM
Quick Reply: remote start not working
