2.0 LDK Build
Old Aug 6, 2016 | 08:05 AM
  #91
DrLoch's Avatar
Originally Posted by hhrfreek
That is great work.
I agree, beautiful work. I've been thinking about what to do with the balance shaft/water pump chain tensioner. Are you going to make a block off plate for that?
Old Aug 6, 2016 | 06:44 PM
  #92
Powermizer's Avatar
The oil holes feeding the tensioner are blocked off because of the front bearing delete sleeves I put in. I wish I could come up with a good name for those and stick with it. :)
Old Aug 6, 2016 | 06:46 PM
  #93
Powermizer's Avatar
No more oil loss to anything that deals with the balance shafts, chain or tensioner.
Old Aug 7, 2016 | 12:07 AM
  #94
Nice work, PM!
Old Aug 7, 2016 | 10:54 AM
  #95
Powermizer's Avatar
Thanks for the kind words guy's!!!
Old Aug 11, 2016 | 08:50 PM
  #96
Powermizer's Avatar
Here is some more Picts of the engine put together minus the exhaust manifold and turbo.
Old Aug 11, 2016 | 08:51 PM
  #97
Powermizer's Avatar
Here is the intake spacer installed.
Old Aug 11, 2016 | 08:52 PM
  #98
Powermizer's Avatar
Throtle body spacer.
Old Aug 11, 2016 | 08:56 PM
  #99
Powermizer's Avatar
Here is the fifth injector installed. I probably won't need it, because of the stage 2 cams having the moded fuel pump lobes, and having the Opel injectors, but I might just use it to help keep the intake valves clean.
Old Aug 11, 2016 | 08:58 PM
  #100
Powermizer's Avatar
Exhaust manifold side.
