2.0 LDK Build
Old May 2, 2016 | 02:25 PM
Back in the day, I'd shave the block 10 to 15 thousands, but those were SBC or BBC engines!
Old May 2, 2016 | 02:43 PM
Powermizer's Avatar
ya I have never seen anything but benefits when making the quench area a little smaller, even making the compression higher and still have less detonation, of coarse there is a line that has to be drawn. better to go a little tighter than looser. That didn't sound good. lol
Old May 2, 2016 | 02:49 PM
But to tight could cause a few bent valves, and or smacked pistons
Old May 2, 2016 | 06:38 PM
Powermizer's Avatar
I like it. Good way to get better valves.
Old May 2, 2016 | 06:42 PM
Powermizer's Avatar
Here is some parts I have. 86mm Pistons!
ARP Studs for head and for bottom end. ARP bolts for timing chain guides.
My Fluid damper
Here are my rods. I started with the ZZP rods and sold them and got these. CARR bolts.
Old May 2, 2016 | 06:43 PM
Very nice, PM!!
Old May 2, 2016 | 06:54 PM
Powermizer's Avatar
Very nice, PM!!
Thanks
Old May 2, 2016 | 06:59 PM
Powermizer's Avatar
The fun part is about to begin!!! I started off buying the ZZP neutral balance shafts, but decided I wanted something different. Here are my ballance shaft delete bushings for rear and front ones I had machined.
Old May 2, 2016 | 07:03 PM
Powermizer's Avatar
So you might be asking why I have bushings for the front. I wanted to run a electric water pump but I couldn't find a location that would let me tie into the pipe between the water pump and thermostat housing sufficiently.
Old May 2, 2016 | 07:49 PM
I cleaned up and merged some posts with pictures for y'all!
