Cold air intake for SS
Old May 19, 2011 | 11:09 AM
  #161
Doctor Who's Avatar
Originally Posted by JPerrydore
That's what I figured.
I have not changed my intake, but things like this are why I keep all the OEM parts that I change. I do it just in case I need service and don't want a hassle for something not being OEM stock. You never know when or why you might need the original parts to go back on the car. Better to be safe than sorry. It is better to have the OEM part than it is to have to quickly try to find that part that I got rid of and can't get it.
Old May 20, 2011 | 11:26 AM
  #162
OVRBOOST's Avatar
HHRSouth, can we see some pics of what you did?
Originally Posted by HHRSSouth
Yep 3" tube all the way to the turbo minus the straight coupler to the turbo and cold air straight out the air box.
The restriction on the factory set up is in the pipe from the air box to the turbo inlet, that pipe has a nice pancake in it as you know.
K&N did round that part out on there aftermarket kit (but kept stock overall diameter), I just did the same thing but the size of the tube is increased to 3" from the air filter to turbo inlet and I'm pulling a little colder air right out of the lower fender behind the fog light. I did drill me out a few more air holes in between the honey comb mesh why I was down there.
Old May 20, 2011 | 11:28 AM
  #163
bad03xtreme's Avatar
Old May 20, 2011 | 11:38 AM
  #164
asanti's Avatar
Do a quick search. He has a thread with pics of his build.
Later
Allex
Old May 20, 2011 | 11:49 AM
  #165
I searched to no avail...
Old May 24, 2011 | 06:26 PM
  #166
Omnigear's Avatar
whats with the SS cai? status?
Old May 24, 2011 | 06:39 PM
  #167
asanti's Avatar
Same as always, it seems to be DOA. Buy a K&N filter or their "CAI" then get tuned for it to eliminate any possible CEL's that may (or may NOT) pop up afterwards. Everything else is one off and won't be made unless it's in batches it seems.
Later
Allex
Old May 24, 2011 | 08:30 PM
  #168
Omnigear's Avatar
awww, i thought they were goin 2 start makin more than 5 this time around.
Old Sep 30, 2012 | 09:13 PM
  #169
Bushmaster11B's Avatar
I customized an AEM dry filter in my original air box. The lid is remove, it does take in hot air, but it's way better than factor or sealed "restricted" K&N filter insert. It's a tight fit. Will try to get picks on here for it. Also, anyone know of a MAF sensor tube/ aftermarket pipe? If I can find one, I may be able to come up with a prototype thermal resistant acrylic box as a functional cold air intake system for the 2.0L. It will be sealed and it will have a pipe that will fead into the fender or bumper for fresh cold air. Any thought on this and I will have a production model come out by next spring if everything goes good.
Old Sep 30, 2012 | 09:21 PM
  #170
If you want one like the Colbalt SS though.... I think this might work:
http://cobalt.dejonpowerhouse.com/ed...BT-IntakeA.htm
