headers
Old Mar 7, 2009 | 11:06 AM
  #81
intofocuszx3's Avatar
I could give two craps about mpg I care about horses!!
Old Mar 7, 2009 | 09:48 PM
  #82
Ed Harvey's Avatar
Catdaddy137, I checked with B&M they told me they didnt and I would have to find a programer. I did ask Summit and they said the same thing. Do you know the part #?
Old Mar 7, 2009 | 11:04 PM
  #83
Ed Harvey's Avatar
Intofocuszx3, We all should be able to have both. 2.4 intake man.,port&polish the head, header, atomize the fuel better& get out the exhaust mabe change the cams and you should get both. Maybe 50-70 x-tra hp.& mpg.
Old Mar 8, 2009 | 12:59 AM
  #84
masterchief1112's Avatar
yep 4T45. which is also the MN5. my bad.
Old Sep 13, 2012 | 06:50 PM
  #85
GOLFHHR's Avatar
Confused
Well after reading this post I am still confused. My simple question is is there a performance improvement between a 2007 2.2 vs a 2007 2.4 exhaust manifold, or are they the same manifold. Checking with the dealership the 2.2 pt # is 12606689, the 2.4 pt # is 12581284 and is $40 more expensive. I also read in the colbalt forum that they had used some 2.2 06 manifolds on the 07 and changed to a new version part way through the year. ??????
Old Sep 13, 2012 | 07:13 PM
  #86
SmootHHR's Avatar
Last post was 3.5 yes ago....
Old Sep 13, 2012 | 07:14 PM
  #87
GOLFHHR's Avatar
Maybe no one has an answer.
Old Sep 14, 2012 | 10:02 AM
  #88
kwe45919's Avatar
I believe you are correct. Check your manifold to see which you'd need. There is a sensor (I forget which) that is on the opposite side and uses a bigger hole I think. I need to reread some stuff on that as well as it'll be my next project.
Old Sep 14, 2012 | 05:09 PM
  #89
GOLFHHR's Avatar
Has anyone taken photo's of a stock 2007, 2.2 exhaust manifold showing the ports
Old Feb 25, 2013 | 08:56 PM
  #90
MiamiHHR2012's Avatar
http://www.crateenginedepot.com/Inta...ents-C667.aspx
Check this page out, might answer your manifold questions.
DANSHHR
2.2L Performance Tech
Jan 20, 2014 05:17 PM
American & Proud
2.4L Performance Tech
10
Sep 9, 2012 07:24 PM
sirrocket1975
26
Mar 3, 2008 07:53 AM
