My Chevrolet Dearler Throttle Body Clean Service
Old Jan 15, 2018 | 04:30 PM
The computer gets no signal if the ignition is turned OFF and especially if the wires are disconnected. See the big red NOTE. That is the reason for step #5.
Why would you crack the plastic case to clean the gears?
In all my years of abusing engines, I have never managed to get gunk built up enough to interfere with the butterfly. I have seen it happen. My dad's '67 Chrysler once had the choke stuck.
Old Jan 15, 2018 | 04:43 PM
Silverfox's Avatar
+ Common Sense tells me that the Air Filter cleanliness is another critical part of keeping the system functioning properly. Much more so then older technology auto's.
In those days I used to concentrate more on the Fuel and Oil filter then the Air filter.
Then when I thought about it, I could pop it out in 15-20 seconds ... See how it looked, Bang it on the bumper a couple times and put it back in. I did usually put a new one in at about 40-50,000 mi.
Fortunately I have never lived in a dusty environment.
Don: I too am still thinking about the Tranny as a possible, so once I get time to do the throttle body/Maf sensor, that should reveal the next step if necessary.
Just finished the front stabilizer bushings (Stock GM) with some silicon grease on them and the 2 Moog stabilizer end links.
The Bucket List is getting smaller.
I wish I still had my heated garage from years ago.
Silverfox
Old Jan 15, 2018 | 06:52 PM
Casa Del Gatos's Avatar
Originally Posted by donbrew
Only 2.0L says to remove it.
I doubt that is your problem, more likely trans shifting.
I notice the one for the 2.0 also doesn't mention the "relearn" process. Does that mean it is not an issue and I can scrub mine with a toothbrush and the CRC spray?
That's what I did with my Mustang and it made a huge difference in smoothness of accelerator.
Old Jan 15, 2018 | 09:21 PM
prod's Avatar
Silverfox
Actually what I think is more of a factor is the vented oil and carbon crap that is pumped in after the air filter.
Old Jan 16, 2018 | 07:14 AM
This will help with that
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
Old Feb 21, 2018 | 03:27 PM
boltfan1953's Avatar
We have a 2.4l 07 HHR and kept getting P0121 code. We replace the Throttle body and pedal. Throttle is stuck on 25% and wont go down. Any suggestions?
Old Feb 21, 2018 | 06:01 PM
I answered you in your other post, I moved that to its own thread, and not attached to a dead thread from 2007
Old Feb 21, 2018 | 06:17 PM
and lets close this before it causes confusion over the multiple posts.
andyb
Oct 13, 2015 06:10 PM
intofocuszx3
2.2L Performance Tech
18
Feb 2, 2009 04:50 PM
Lone Ranger
Jun 29, 2007 09:12 PM
cipher
Jun 13, 2007 09:06 PM
