ATOTO android radio installation question
Old 02-06-2019, 01:20 PM
Laplante's Avatar
is this what a nead that will provide me the 12 volt Accessory / Ignition too ?
Laplante is offline
Laplante's Avatar
Amazon Amazon
Laplante is offline
Old 02-06-2019, 01:29 PM
Oldblue is offline
Old 02-06-2019, 03:32 PM
Technical Moderator
I tried to explain that there is no switched wire in the OE harness because that part is handled digitally by the computer.If you don't use the interface you will not be able to use steering wheel controls or have "door open" chimes.
If you need to find a source for switched 12V look on the BCM (the inside fuse box, below the radio) There are 3 fuse locations marked "spare" they are unused switched circuits, 2 20A 1 10A. If you don't understand tapping into a fuse box maybe you should find someone who does.
If you go to the crutchfield.com site you will find a wealth of information regarding installation. Your particular model does not really matter in regard to what wire is what.
I was not offended, just didn't know why you would be shouting after you had acknowledged the answer. That only gets you negative attention.
donbrew is offline
Old 02-10-2019, 02:43 PM
Laplante's Avatar
thx very mush for your time !
Laplante is offline
Old 02-10-2019, 06:24 PM
Is that the Canadian in you, or simply a typo, mush .
But seriously how is the install going
Oldblue is offline
DoomBuggy
Fuel Economy - Hypermiling
04-19-2012 05:00 AM
SargeRN
10-05-2011 08:21 AM
Tominator
08-13-2011 06:44 PM
bobiroc
06-19-2011 07:42 PM
fatphil
01-05-2011 04:23 PM
Quick Reply: ATOTO android radio installation question
