Tweeter from behind (to potrude out to the front of the vehicle)
Old Sep 4, 2012 | 07:56 PM
hhrumadbruh's Avatar
I am interested in buying some tweeter (maybe more?) to put somewhere facing the front of the vehicle.
Perfect place would be anywhere that points them out of the front windows (the stock tweeters basically bounce out to the rear and sides)
Pictures or links would be most appreciated :)
Open to any ideas. Has to look nice though. Not just gonna drill a hole and mount some tweeter on the sub box - nothing ghetto as that, but maybe somewhere in between?
Old Sep 5, 2012 | 06:43 AM
SpaceCowboy's Avatar
I have mine on my A pillars...I suggest removing the stock ones and replacing with a nice set of components...but if you are keeping a factory head unit the rear speakers are 8 ohm so you may be limited on rear speaker options
Old Sep 5, 2012 | 11:23 AM
prod's Avatar
I used to have a sub box with mids and tweets built in. sounded great but had to be facing forward as they were all on the same side. No reason why you couldnt build them all in, just make small inner enclosures to isolate them from the subs. Keep in mind it is for shows because imaging is poor from a driving position.
Conventionally the best sound is when tweets are mounted in door panels close to the mids using pivot mounts, that would be my choice.
Old Sep 9, 2012 | 09:53 PM
Eric B's Avatar
Sail Panels.
Shanes0406
Jun 12, 2013 12:58 PM
hhrumadbruh
Dec 8, 2012 02:46 AM
sking1973
Jun 25, 2012 11:41 PM
Dieselracer
Oct 19, 2011 01:42 AM
jgschroeder99
Mar 17, 2010 08:43 AM
