Since you give no details. You could just measure your bar; Wrap a piece of string around it and measure the length then remember high school geometry.
As stated earlier it is either 25 MM or 23 MM. a tiny bit smaller than 1 inch.
Good evening team. Quick question. I’ve bought non OEM sway bar bushings for my 2008 LT and they are 1 inch bushings. However, there’s still play and clunkyness. Will buying 24mm bushing still fit ?
your front sway bar is 25 mm , not 1 inch not 24 mm , 25 mm.
I’ve tried the 1” poly bushings from energy suspension and they were loose made noise, I tried Moog , to small in the bracket, I went back to AC Delco, you get 2 for under $10.00
Note that is just $7.20 CDN funds! For those AC Delco bushings, clean the bar of any dirt and grease, install them clean , no grease! With the split facing to the rear of the car.
