quick strut noise
Old Aug 14, 2013 | 11:38 AM
  #41
Originally Posted by donbrew
The spring should not have any "bearing"(pun) on the situation. The weight of the car should push everything down so that it comes down onto the spring, even if there were no spring the car should come to rest on the top of the shock housing. One thing I was wondering about was the LCA hanging on something. If one of the links is 12" and the other is 10" there could be a problem (whatever the brand).
Something is preventing the SHOCK from compressing, or at least the body from dropping down to the spring.
Agreed!!!
And the number of coils comparing the old springs to the new springs doesn't necessarily mean a thing - the length is important of course, and also the spring rate (meaning the amt. of weight for a specific drop or compression of the spring).
Old Aug 14, 2013 | 12:19 PM
  #42
hurst2001's Avatar
i have a pic of the old strut and new strut in my gallery and trying to post .https://www.chevyhhr.net/gallery/fil..._1rsz_img_0104
Old Aug 14, 2013 | 01:14 PM
  #43
What we are saying is: unless there is some obstruction on the shock absorber shaft, the problem is with the car not the strut. Might even be the other side stuck on something.
Old Aug 14, 2013 | 06:47 PM
  #44
hurst2001's Avatar
Ok i went measure height on both sides ground to bottom lip on fender above the tire and it came out to 27 1/2 inches equal both driver and passenger side . I also use some lube on the steering joint under the steering wheel by the fire wall.. I am wondering if it the steering rack?Anyways i checked the spring on the drivers side today it seems that it get tighter less movement...still have creaking noise maybe motor mount ? Ok i came too conclusion it is a creaking noise when turn the steering wheel while the car standing still and it got to be either sway bar bushings or the new strut mount and i am not going to post no more till i find the problem ,so i like to thank donbrew and whopper ..I mean anything that's make a creaking noise has too be some bushing dried rotted or cheap strut mounts . the car does sit outside and i replaced sway bar bushings three years ago . I thank god for this website
Old Aug 19, 2013 | 04:16 PM
  #45
hurst2001's Avatar
Ok final update the strut mount bearing was upside down in the assembly and was like two in row cant be, but that was the problem ,my mechanic took it all apart and flip the bearing over and know the strut is smooth no creaking and the coil is tight ..on drivers side and this company is going to get the bill for 50.00$.. Other then that i was puling my hair out to find the problem well case closed
Old Aug 19, 2013 | 05:54 PM
  #46
Speaks poorly for their quality control - but now we know, and it's something else we can add to the noise causing list.
Glad you got it solved. Cool.
James76
7
Mar 29, 2015 05:06 PM
843de
Mar 25, 2013 05:22 PM
Musicguy
May 1, 2012 09:56 AM
dozol22
14
Nov 20, 2011 06:10 PM
barfan1
21
Oct 13, 2011 11:11 AM
