TCE Plus-2 Brake Package for the SS! (56K WARNING!)
Old Oct 11, 2008 | 11:46 PM
  #31
Yonash's Avatar
sure do, i will get them up here hopefully tomorrow.
Old Oct 12, 2008 | 06:01 AM
  #32
Chevy SS's Avatar
Excellent, thank you.
Old Oct 12, 2008 | 12:04 PM
  #33
Yonash's Avatar
here you are!
Old Oct 12, 2008 | 12:25 PM
  #34
hhrbama's Avatar
You did an excellent job of documenting your brake upgrade. I noted that the stock pads that are pictured differ slightly from the stockers on my 2006 HHR. For whatever reason the friction surface is smaller (or at least it seems that way). I wonder if this is an attempt by GM to alleviate the brake shudder everyone refers to as warped rotors?
Old Oct 12, 2008 | 07:15 PM
  #35
Chevy SS's Avatar
Originally Posted by Yonash
here you are!
Thanks, I know you stated they feel the same normally, but when you need them they are there. With that statement in mind would you have paid $1400 for this upgrade? I know you got a discount, but do you feel it's well worth the normal price?
Last edited by HillsdaleHHR; Oct 12, 2008 at 07:16 PM. Reason: Removed pic from quote
Old Oct 12, 2008 | 09:08 PM
  #36
Yonash's Avatar
honestly, yeah, the rediculous improvement in braking power is well worth the full price, especially if you have done some power mods, and even more so if you have some kind of track use, a little or a lot, planned. if it weren't for how quickly the seatbelts lock, when i was bedding my brakes, my little brother's face would have found my dash in a split-second haha.
hhrbama, the brakes on my SS (the stock brakes) will likely be different from yours, being ours is designed to be a bit more performance oriented. i don't know enough on theory and physics of brakes to accurately say why my pads would appear smaller than yours, other than i believe my piston in the caliper is a bit smaller (Todd can clarify this, he has the measurements), possibly for brake bias reasons, pressure differences front to rear, etc.
Old Oct 12, 2008 | 09:25 PM
  #37
Chevy SS's Avatar
Thanks, I still want to do these, just need the money and to convince myself I need brakes before more power!
Old Oct 13, 2008 | 08:44 AM
  #38
Todd TCE's Avatar
Former Sponsor
The pad size is based on the piston size in the caliper they fit. The SS uses a much smaller piston than the standard car thus the fit of the pads will be smaller too. It can't be quite as large or you'd have a small circle pushing on a large, flat surface. With that you end up bending the plate with high pressure and can turn the plate to a banana shape of sorts. That being the case the size of the pad really has no bearing on the function of the brakes- large or small the pressure is related to the piston size only and not the pad size. The larger pad would certainly last longer but not work any harder.
glenngeb
Feb 4, 2019 03:56 PM
Rjj
Oct 22, 2017 08:56 AM
hurst2001
10
Oct 9, 2013 03:07 PM
foolmoon_design
Aug 31, 2010 10:02 PM
MOTRV8D
Mar 12, 2008 07:35 PM
