Auto Trans Check Plug - Where Is It?
Thank you guys. Doing this today.
Do you happen to know if there's a significant amount of coolant that stays in the engine block when doing a coolant flush and fill? I want to replace the coolant (mostly water at this point) and run some prestone coolant flush through it. Do I need to drain and fill several times to dilute the stuff that gets stuck in the engine block or is it fine if I just do one drain and fill?
Drain, fill then drain again and refill, and burp the system, use 50/50 Dexcool, I use the premixed Prestone brand. And while you’re draining the system replace the thermostat an AC Delco 131-158 180 degree is the only one to use, many have tried other brands and experienced failures. Including myself.
