Auto Trans Check Plug - Where Is It?
Old Nov 16, 2020 | 07:58 AM
Fill it from the fill port, on top of the transmission, when it starts to drip out the level check port, stop adding fluid.
Old Nov 16, 2020 | 11:17 AM
Engine running!
Old Nov 16, 2020 | 04:08 PM
Greg Bystritski's Avatar
Thank you guys. Doing this today.
Do you happen to know if there's a significant amount of coolant that stays in the engine block when doing a coolant flush and fill? I want to replace the coolant (mostly water at this point) and run some prestone coolant flush through it. Do I need to drain and fill several times to dilute the stuff that gets stuck in the engine block or is it fine if I just do one drain and fill?
Old Nov 16, 2020 | 04:52 PM
I would not use chemicals to flush. Aluminum alloys don't like it.
Old Nov 16, 2020 | 05:28 PM
Drain, fill then drain again and refill, and burp the system, use 50/50 Dexcool, I use the premixed Prestone brand. And while you’re draining the system replace the thermostat an AC Delco 131-158 180 degree is the only one to use, many have tried other brands and experienced failures. Including myself.
Yamahhr
10
Oct 31, 2017 06:03 PM
TomR_here
Apr 29, 2016 03:48 AM
SteveMaine
Dec 22, 2013 07:03 PM
donald cole
Jul 17, 2012 10:50 PM
woodchuckd11
Maintenance and Upkeep
Mar 3, 2011 12:48 AM
