2008 hhr eng pwr reduced
Old Feb 25, 2019 | 01:51 PM
  #41
Great news, keep an eye on the CEL . It should be all good now!
Old Feb 25, 2019 | 02:02 PM
  #42
I hope you realize that disconnecting the battery cables while replacing your battery, will clear the codes stored in the computer.
That's the poor-mans reboot or as some around here call it, a battery "lobotomy".
Old Feb 25, 2019 | 02:22 PM
  #43
nu2HHR's Avatar
So, what’s the next step? I had no idea. My other vehicle is a 2005 GMC Canyon with 300,000 miles. The maintenance was easier. Do I wait for the codes to reappear?
Old Feb 25, 2019 | 03:10 PM
  #44
Doc brown's Avatar
There isn't a next step. The codes should not reappear. It sound's like you fixed it.
The Canyon maintenance wasn't easier, you just never had problems. It would have done the same thing with a bad battery. I'd bet there's a few Canyon owners out there with bad batteries that experienced most of the same issues you had with your HHR. I had the same issue a couple of years ago with my GMC Sierra. My battery was at 12.3 volts. It wrecked all kinds of havoc, what made it worse was that it was -5 outside at the time.
Old Feb 25, 2019 | 04:36 PM
  #45
Drive it...
Old Feb 26, 2019 | 01:56 PM
  #46
PulpFriction's Avatar
There is static build up on the vehicle too. When you touch the vehicle it shocks you.
At next break in the weather I'm going to spray my seats with staticguard. Why? I get shocks from my 2008LE even in humid weather. I think MAYBE it's just static from the upholstery, but the radio used to "snap" randomly when I drove, and I thought that could be related. I have since replaced all audio including speaker w/ aftermarket speakers and vintage GPS/radio, plus retrofitted an OEM subwoofer. No more "clicks" but the unit crashes periodically, and I still get shocks. I'm leaning toward upholstery cause both shock and radio problems. Hope so because I dunno what else would cause it.
Old Feb 26, 2019 | 02:47 PM
  #47
https://www.wikihow.com/Get-out-of-a...ic-Electricity
Amazon Amazon
Old Feb 26, 2019 | 02:55 PM
  #48
Cat Man HHR's Avatar
What is The Canyon maintenance ?
Is that slang for changing the battery ?
Thanks
Old Feb 26, 2019 | 03:16 PM
  #49
nu2HHR's Avatar
Update, the display has shown the 'low tire pressure' light. I will wait later until I do the scanner to check the codes. I'll look into spraying the seats with static spray as well. Thanks
Old Feb 26, 2019 | 05:15 PM
  #50
Thanks
Post #43 (his other vehicle)
donbrew
0
Mar 22, 2016 08:10 AM
possum67
Feb 2, 2010 10:24 AM
FallRiverHHR
Feb 24, 2009 10:35 AM
MDA
Nov 5, 2007 07:57 AM
da_loca
Dec 8, 2006 12:34 AM
