Aftermarket remote start/auto headlamps
Old Nov 12, 2013 | 01:38 PM
ssmontecarlo82's Avatar
I'll have more to report later. I just got a text to bring it back to the shop.
Old Nov 12, 2013 | 05:08 PM
Lucky's Avatar
Originally Posted by Heavywrecker
Beieve it or not....don't fuss with wiring and such, just give the e-brake a pull and the lights won't come on until you release it. Hope this helps
That's a good trick. I forgot about that
Old Nov 12, 2013 | 05:41 PM
skyline26's Avatar
im using a Clifford remote start - 2 way - and only the parking lights come on when its running..i also have HID's installed so thats a weird one for you and i dont need to engage the e-brake
Old Nov 12, 2013 | 11:20 PM
Heavywrecker's Avatar
Mine is also a 5-spd so the ebrake is always on. MOST remote starts use the parking lamps, but I have seen some use the headlamps as well. And if anyone has any friends that have access to a tech2, it is possible to change the drl to the parking lights. Just an FYI.
Old Nov 13, 2013 | 03:16 PM
SpaceCowboy's Avatar
Hooking up parking lamps or headlights is on the installer. I haven't seen one system that turned on head lights via data.
Old Nov 13, 2013 | 04:39 PM
The OE RS does turn the headlights on, at least on my old 2008 and in the U.S.. May have been DRL, I never cared enough to check.
Remember, the 2006 DRLs are the parking lights, and maybe other years in Canada. Several other quirks are inherent to 2006-2007 and Canadian models.
Old Nov 13, 2013 | 09:58 PM
Hey all,
Went into the shop today. The installer forgot to hookup the ground to the autolamps. Even after, he had to put a relay in to keep the autolamps from coming on in dark conditions.
As it sits now, I engage the remote start, the headlights come on briefly, and then the HHR sits there with the parking lamps on while it warms up. I'm satisfied with this setup, because it doesn't shine my neighbors for more than a quick second.
Old Nov 13, 2013 | 10:24 PM
Lucky's Avatar
Originally Posted by ssmontecarlo82
Hey all,
I'm glad to here you got it fixed. You are a good man. These days it seems that most people could careless if they upset other people if it don't effect them.
Old Nov 16, 2013 | 09:15 AM
khalifa's Avatar
Can I have the code for the Clifford remote start - 2 way that you used.
Thnx.
Old Nov 16, 2013 | 09:04 PM
Thnx.
Code?
hhr06NJ
Aug 25, 2014 09:58 PM
pdmorris1
Apr 29, 2014 09:11 PM
bwhite757
Feb 13, 2010 09:55 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
