So im slowing working on the wrecked HHR, first thing first, how do you do the bumper bracket? The passenger side one is bent, bad! I need to replace it, is it a cut and weld or riveted?
Stock photo of new part
they weld on , so best to weld it again drill out the spot welds on the orig one and use the holes to weld the new one back on the frame rail good luck
That does not look anything like what the service manual shows. They say this one welds in, drill out the old welds.
The description of your part is "(BOLT-ON COMPONENT OF IMPACT BAR ASM)", it seems to bolt onto the end of the impact bar to hold the fascia on.
