heater not turning on in my 2008 HHR
Old Mar 14, 2018 | 09:42 AM
The resistor is near that spot also.
Old Mar 14, 2018 | 02:09 PM
Jens2008chevyHHR's Avatar
how would I know which it is - the resister as you mention - or the fan? my boyfriend tapped on the console just under the glove box and when he did the heater started blowing again, so we asume it is the heater fan blower... how do we know for sure if it is this or the resister?
Old Mar 14, 2018 | 02:21 PM
It would not be the resister itself, but connectors could be loose anywhere from the switch to the fan. That wire goes to ground, the other wire on the fan motor goes to 12V.
If the resistor fails the fan will run but only on high.
Old Mar 14, 2018 | 02:34 PM
Loose connections, to the resistor or the fan, check them both.
Old Mar 14, 2018 | 02:41 PM
Cat Man HHR's Avatar
This video shows how to change out the blower motor. It's located under the glove box facing up. The guy shows a ring that comes with the new part but doesn't give any info on it. Hope this can help you and others that experience the same problem.
Did find this:
https://www.autozone.com/cooling-hea.../994059_0_1526
lriker
Mar 20, 2015 05:51 PM
ejb1982
Jan 31, 2013 01:59 AM
J-Madness
Dec 3, 2012 11:54 PM
avanbaggett
Nov 3, 2010 02:22 PM
Goose
Jan 20, 2009 07:33 AM
