K&N intake box.
Old Jun 22, 2020 | 10:46 AM
PulpFriction's Avatar
K&N intake box.
Thinking about a K&N #63-3069 high flow intake kit, intake tube, bulging box cover, etc. Buying used, cheap. Don’t know whether to rush to put it on or wait.
Didn’t find anything recent w/ admittedly lazy search. What’s the latest wisdom? I see mixed reviews. Will it really require a tune?
2010 SS, 5-sp, performance package, 120k, bone stock.
Old Jun 22, 2020 | 11:30 AM
https://www.knfilters.ca/chevrolet/h...l-l4-gas/2009/
It is really just the elbow pipe that improves the airflow, depends on what the asking price is and the condition of the parts
Old Jun 22, 2020 | 11:56 AM
Cat Man HHR's Avatar
Call K&N like I did and ask for a replacement pipe from air box to engine.
I my case it was air box to turbo.
They might ask you why.
Tell them you had a garage mishap and the pipe is damaged.
Once you have the pipe you might have to get different silicone pipe adapters.
I had to and found them cheap on Ebay
Use a stock GM air filter.
Make sure your cold air tube is good and you're all done.
Old Jun 22, 2020 | 11:20 PM
Thanks for the great insights. Asking is $100, used, clean and complete.
Found installation instructions on line. It seems the K&N filter isn’t really any bigger that the stock version. I do like that it clamps on so presumably can’t slip off. Don’t see a huge value in the supposed economy of the cleanable reusable filter since it is claimed it can go up to 100,000 mile (!) between cleanings. Greener, I guess, but a trivial cost difference. In any event, looks like I can interchange the new filter and the original easily. I agree the main benefit is likely the intake tube.
Old Jun 23, 2020 | 09:24 AM
Greener is debatable also. You have to wash that old oil out, it's gotta go somewhere.
If you're not careful re-oiling, you'll foul the MAF sensor...
Old Jun 23, 2020 | 10:19 AM
I only oil mine in the incoming air side, just a spritz, then dab away any extra oil with a paper towel. Never had any issues with the K&N filter element , been using them since the 80’s .
sshhr08
2.0L Performance Tech
Jul 1, 2015 02:31 PM
Joshua022
2.4L Performance Tech
44
Aug 4, 2012 01:49 AM
TiggersHHR
2.2L Performance Tech
17
Feb 19, 2011 09:40 AM
Razz2o4
Apr 22, 2010 01:54 PM
intofocuszx3
Sep 16, 2007 08:51 PM
