Oil Filters K&N and Mobil One
We sell the AC Delco Filter Kit with Cap. This way our customers have an extra cap if theirs becomes damaged or broken.
For the little extra cost, it provides a lot of security.
Hope it helps,
Hope it helps,
OIL FILTERS… alphabetical
ACDelco
Standard w/cap pf2259g $14.99 SoCalStore
Standard w/o cap pf456g $
NEED TO PRICE AT LOCAL GM PARTS DEPT
AMSOIL “Ea” oil filter… NO INFO YET
BOSCH… NO INFO YET
FRAM
Standard $9.89
EXTRA GUARD… CH9018 $22.85/12.89
K&N… HP-7000… NOT AVL 09/06
MOBIL One Extended… Not AVL 09/06
NAPA-GOLD… FIL 7082 $
PUROATOR…
Standard L15436 $10.50/8.99
PureOne PL15436 $21.10/17.99
STP… S9018R $7.19
WIX… 57082 $
REDFLYR,
Champion makes the oil filters for Amsoil, Bosch, K&N, and Mobil 1 Extended.
There should be enough interest in the HHR, Cobalt, and other cars that use the same oil filter, to have one of those companies, plan on making that filter in the near future.
went to the Schucks auto web site and drilled down to the FRAM oil filter... then selected "also works on these vehciles"... there are several cars using the ch9018. guess filter mfg haven't seen the magic number yet... what ever it might be
Guys,
I recently installed the K&N Intake, and now I have the Oil cap sticking out from the original Turtle Air Box.
Does that come off, and what is a source for a new oil cap that I can screw to the valve covers and take that protruding pipe out.
Oh... I noticed someone had a oil filter cap in the Gallery that said Mobile 1 on it. Where can I get one of those?
Thanks,
Keith
Thanks,
Keith
Where the extension tube goes into the valve cover the "thread" is the same as the cap. Just unscrew the tube and the cap will go directly into the cover.
For a Mobil 1, the thread is the same as the recent Corvette/GTO. You can get them from a dealer. Billit caps are also available on eBay.
Guys,
Thanks,
Keith
Thanks,
Keith
Also, it will be harder to add oil with the tube removed, and yes I know it look's better removed.
Have not done mine yet, still thinking about doing it though.
Good luck.............
Lone Ranger
Jun 29, 2007 09:12 PM
