Possible self-alignment?
Old Feb 4, 2024 | 07:25 AM
Wheel hubs are not interchangeable between the LS/LT model and the SS different size cv axel
Old Feb 4, 2024 | 10:58 AM
You can get a laser level for less than $20.
https://www.harborfreight.com/laser-marker-93242.html
$5
https://www.harborfreight.com/painti...vel-67800.html
$13
Old Feb 4, 2024 | 11:15 AM
I tried that, to hard to find a flat surface on the wheels to get the magnetic level to stay in place.
Old Feb 4, 2024 | 03:42 PM
hhrumadbruh's Avatar
Probably want to hit tire to tire vertically, or the edges of the outside of the rim/spokes. Then space it out as needed. Maybe prop something up to hold it up.
Old Feb 4, 2024 | 03:47 PM
set a box in front of the front tire set the level on ; sight front to back laser touching at 4 points on tires (2 each).
Old Feb 4, 2024 | 03:52 PM
  #26
I set it on a cement block and pointed the laser from just behind the rear bumper towards the front, I measured at the rims on the back and front of the rear tire to make sure it was square then measured the front wheel, I found the measurements to be fairly accurate, but the battery went funny and the laser was toast, so this last time I checked with the tape measure.
KenK
Feb 17, 2023 12:42 PM
davidfr
Maintenance and Upkeep
Jun 15, 2019 07:26 PM
pbatmen
11
May 19, 2017 06:32 AM
EZDAY
May 22, 2016 07:08 PM
SwaintaN
Dec 13, 2013 09:48 PM
