V8 HHR Build
Old Apr 11, 2016 | 04:48 PM
  #831
shouldahadaV8's Avatar
sorry spelling were..lol
Old Apr 11, 2016 | 05:05 PM
  #832
lasater's Avatar
Originally Posted by shouldahadaV8
I'm sure this has already been asked somewhere in the thread....But why where you unable to use a stand alone harness?
The harness will be a modified stand alone. I still want to keep as many stock HHR items as possible. The HHR guages won't work because one car uses CAN buss and one car uses SERIAL buss.
What are you using to drive your speedo? Your sbc doesn't have an ECM does it?
Old Apr 11, 2016 | 05:24 PM
  #833
okay check this out..
so mine uses the factory body harness with a stand alone engine harness...the gauges are classic instruments Bel-Era designed to retrofit into a 55 Chevy but slightly modified to fit into the HHR dash ... I'm not sure exactly how it works but it has some type of small ECM that plugs into the tranny.
Old Apr 11, 2016 | 05:30 PM
  #834
lasater's Avatar
Yeah, that's similar to what l'm doing. The trick is getting the HHR fuse block powered up. What about your a/c and heater? Stock controls?
Old Apr 11, 2016 | 05:38 PM
  #835
yes stock on ac/heat... but the stand alone controls only the drive train and has it's own fuse block.
Old Apr 15, 2016 | 08:54 PM
  #836
lasater's Avatar
ECU Programming
I mailed of the Ls1 ECU today to Sinister Performance in Fort Wayne for programming. They came highly recommend and Ryan Gick, the owner
seems very sharp. The wiring continues....
Old Apr 15, 2016 | 10:50 PM
  #837
A build like this, it's always down to the wire!!
Old Apr 28, 2016 | 07:37 PM
  #838
papa_jo's Avatar
been awhile since a post,, are you out riding around now??
Old Apr 28, 2016 | 07:40 PM
  #839
Naw! Just the little things that don't look any different in a picture, right Cliff?
Old Apr 28, 2016 | 10:19 PM
  #840
lasater's Avatar
Yeah, it looks pretty much the same. You guys don't want to see I pictures of that.
