V8 HHR Build
Old Apr 29, 2016 | 05:44 PM
  #841
Fox Hat's Avatar
Hope to see your HHR in here someday!!
Rodding Revolutions ? REVOLUTIONS? IN DESIGN? STYLE? QUALITY? INNOVATION? PERFORMANCE
Old Apr 29, 2016 | 08:28 PM
  #842
oceangoer's Avatar
Great Progress. !!
I've got a near complete 2009 2.2 l body wiring harness out of my Mule Panel. So if you need a connector or section of Body wiring, Let me know and I'll send your way. I also have all the various module connectors and misc controllers.
I went through pretty much the same process as your doing,, the cutting back and delete unused signal wire for PCM wiring harness, lot of tedious work. My only advice is to place the various "Engine" grounds on the engine where they were originally located. To date Zero PCM Codes.
My first LS1 & 6 speed went into my '56 Chevy 210, and I now wish that I'd installed the PCM in the engine compartment, I still can't stop the Wind from that hole in the dash.... My PCM is stand alone, except for the Speedo and Tack signals. But, after I had completely installed the Auto Meter Instruments I had to pull the Speedo and Tack out, after dropping and steering column etc, because I didn't "Read" that the Tack had to be Set for a "4" cylinder. I had the Cruise, A/C, MAF, CPP, secondary Oxy Sensors, & ETC, deleted by the PCM Programmer.
One of the very Wonderful "Things" about the LS1 and it's PCM, besides the Power, is that I've Never Ever had to touch the Engine in "9" years, except oil changes and a bath now and then. Time for new headers though, the Ceramic coating;,,,
RE the Oxy sensors. Over the Years I've read tons regarding the placement of the front sensors. I spoke with a few LS1 etc Header manufactures Tech Support and in the end placed the bungs just after the 4-to-1 collector. The engine runs perfectly and with no EGR, will pass the emissions test, I had to know...
Lots of great work !!
Old May 1, 2016 | 01:58 PM
  #843
lasater's Avatar
Wiring Harness
It's not just the engine compartment wires, I'm completely removing the unused wires all the way back. Im working on the "low fuel warning light right now. Of course it goes almost bumper to bumper.
Old May 1, 2016 | 02:06 PM
  #844
Fun stuff!! Tedious and exacting!
Old May 2, 2016 | 02:30 PM
  #845
papa_jo's Avatar
that's about as much wire in a telephone control room, good luck
Old May 7, 2016 | 09:11 PM
  #846
lasater's Avatar
Ceramic Coating Done
As the tracing, removal, cutting, splicing, lengthening, shrink tubing and bundling of the wiring continues at a snail's pace, the exhaust system got back from the coaters. It came out pretty sweet. It won't rust and it will keep the heat inside the tubes a little better.. I also mounted the QuickTime low profile cutouts. Something else to wire in.
Old May 7, 2016 | 10:08 PM
  #847
Aye the pipes! Soon they'll be calling!! Hopefully way before next St. Patrick's day.
Old May 8, 2016 | 01:25 AM
  #848
Thanks for this thread - love the pictures and the details. I don't check it out too often............ cause I get jealous.
Keep it up - I can hardly wait to see the final results.
Old May 15, 2016 | 06:13 PM
  #849
lasater's Avatar
Wiring Harness Mods
Soldering away, straightening things out. It is a ton of work just to mone the fuse block to to other side of the engine compartment. Im working on connector X2 here.
Old May 15, 2016 | 08:49 PM
  #850
Fun ain't it!
