Water pump
Old Jul 21, 2019 | 01:52 PM
1973laguna's Avatar
Water pump
I have a 2011 hhr 2.2liter I need to know where the drain plug is for the water pump . Thank you
Old Jul 21, 2019 | 02:02 PM
How-To replace water pump
Old Jul 21, 2019 | 02:16 PM
1973laguna's Avatar
Thank you donbrew. Is the plug a regular bolt because that is all I see also is that under the car on the passenger side ?
Old Jul 21, 2019 | 02:18 PM
Yes. I put a link to the how to in my post.
Old Jul 21, 2019 | 02:24 PM
1973laguna's Avatar
Flushing
Thank you , I have always used a flush and fill kit to backflush the cooling system on my cars but I don’t know if I should with the hhr because of all the sensors /electronics and the alternator is right under the radiator cap and I worry about it getting ruined. Thank you .
Old Jul 21, 2019 | 02:49 PM
I tried that I was not happy with it. Doesn't it rain in Oregon?
Old Jul 21, 2019 | 04:00 PM
1973laguna's Avatar
Oregon
Oh yes it does , but we get our fair share of good weather too , So just flushing the radiator and draining the water pump should be sufficient and of course putting in new coolant.
Old Jul 21, 2019 | 05:13 PM
Bottom line, remove the water pump drain plug, remove the thermostat, open the radiator petkawk, and all the coolant will drain out. Then you install a new ACDelco 131-158 thermostat(don't try any other)and close everything up. 2 gallons of new 50/50 Dexcool will be a little more than enough to refill.
Then burp the cooling system by raising the nose of the vehicle 8" or more, and run the engine until all the air bubbles escape. Top it off, replace the cap, and recheck the level every morning for about a week.
"Flushing" is really not required. The specific thermostat, and proper burping is very important.
donbrew
Jan 21, 2013 08:00 PM
ebritt
Jun 12, 2012 05:12 PM
wagoneer
Jan 12, 2010 11:17 AM
masterchief1112
Oct 19, 2009 03:47 AM
River
Sep 28, 2009 07:39 PM
