Weird light issue tonight
Old Dec 29, 2010 | 09:14 PM
Rod Run's Avatar
I was walking out of work tonight and started my remote starter. As I walked up to my HHR I noticed a light below it, in the rear. When I went behind the HHR, I saw a small light hanging while it was wrapped in an ice block.
After I looked at it, I realized that somehow the rear sidemarker light wire got built up with ice from the road, then it somehow popped out the light from it's bezel.
I just had to break the ice block off the wire and then twisted the light back into it's socket.
First time anything like this has ever happened to any car I've owned
Old Dec 29, 2010 | 10:11 PM
Must have been just enough ice to pop it out, I'd think it would have to be a pretty good chunk. Although you might have had something bounce up from the road and knock it loose, either way...kinda weird.
Old Dec 29, 2010 | 11:16 PM
geg's Avatar
geg
It happens.
Frost. The plastic becomes brittle. Squash - clip cracks or falls away. Lamp is not fixed.
Old Dec 29, 2010 | 11:33 PM
Rod Run's Avatar
Nothing was broken, it was just a huge hunk of ice. Probably around three or four pounds and it was frozen around the wire leading to the light
Old Dec 30, 2010 | 01:25 AM
Ice is heavy, & that is freaky...But I can certainly see the iceburg winning that battle..
sunbound
Aug 14, 2013 03:59 PM
LolaIsMyHHR
Nov 30, 2011 08:05 AM
GDZHHR
Jul 17, 2010 03:33 PM
Czechman
May 31, 2010 04:13 PM
goatcheez
Jul 9, 2008 10:07 AM
