Adding radio buttons on steering wheel
Old Mar 13, 2007 | 04:38 PM
  #281
HonestBlues's Avatar
Just got done with mine and they work great! Thanks to courthousedeb for her awesome instructions I didn't have any chill pills so I took one of my pain pills for my back For my next project I hope to install a new grille...just haven't made up my mind about what kind to put on it yet. HB
Old Mar 13, 2007 | 05:02 PM
  #282
Nazramoth's Avatar
Originally Posted by MCANAW
I did the same thing. Mine was hard to unplug and pulling on it, I broke the signal return. I did not order parts thru my dealer, so I took it in and told them it just quit working. Fixed for free. Good Luck
I tried to redo my wiring harness this past weekend... I wanted to run them back through the back of the interior where they're supposed to go, where the original harness ran.
But to do that, this big metal plate has to be removed...
Unfortunately, the "hex" screws holding it in place are on so damned tight... I couldn't budge them a hair and they broke my ratchet! I'm gonna have to hope and pray when I go in and ask the Dealer about replacing that turn signal now, as it sounds like it broke as a result of me tugging and pulling on the original wiring harness inside the wheel from when I first installed the controls last week.
Old Mar 13, 2007 | 07:22 PM
  #283
courthousedeb's Avatar
Glad to hear the instructions came in handy once again HonestBlue...when I did mine there were none and I struggled a bit trying to figure it out and not break anything in the process.
Nazramoth...sorry to hear about your ratchet. I did mine ages ago and didn't run the wires back thru and everything works great. Sorry to hear about your signal lever...I'm sure if you don't tell the dealer you did it you'll be fine. They probably won't even know that you added the buttons anyway. Good luck and let us know how it goes.
Old Mar 13, 2007 | 08:56 PM
  #284
fast98ws6's Avatar
did anyone come up with the cover part number for a 2007 so the colors match?
Old Mar 13, 2007 | 09:11 PM
  #285
karen1953's Avatar
For which color?
Old Mar 14, 2007 | 12:38 PM
  #286
fast98ws6's Avatar
the cruise panel on the wheel is more of a silver color on my 07, and charcoal on the 06.
Old Mar 15, 2007 | 01:17 PM
  #287
Linepainter's Avatar
Just picked up my parts today going to try to install this weekend
Old Mar 18, 2007 | 03:19 PM
  #288
Installed the switches they work great
Old Mar 18, 2007 | 03:30 PM
  #289
tamar0804's Avatar
Could someone tell me the parts numbers i need and the parts names, i have an 2007 LT1 its a gray inter.
Thank you in advance,
Kristy (aka Tamar0804)
Old Mar 18, 2007 | 03:36 PM
  #290
15234337 Steering Wheel Module - 15244413 Switch - 15234343 Harness -
here are the part # you should be able to get them fron the dealer
