Adding radio buttons on steering wheel
If you really want this mod you can get the dealer to do it for you. Order the parts through the dealership and ask them to install them. It should be 1/2 hour labor. It is a little more expensive that way but you will have the upgrade and a great upgrade it is. Mine is in use every day.
Don, yea it doesnt look too bad of a job but just a tad worried about the airbag , Im sure I m worried alot about nothing lol,,,,,,,,,,,
08, I may check with the dealer just to get a price! SO far they have treated my right!
Thanks guys
Thanks guys
X2
I’ve had most every airbag electrical connector apart, with no problems.
I imagine the original early units did not have all the shorting connectors/contacts as safety measures built in. In case readers do not realize it most every connector has shorting bars inside the connector that short out the ignition/activation leads of the airbag and wiring. The act of plugging the connectors together removed the shorting bars and completes the connection.
Dumb question I know but have to ask, Does the HHR 09 steering wheel w/radio buttons plug right in and bolt right up? Is it easier to install new steering wheel with buttons then the conversion?
Thanks from a Tech Tard in waiting :)
Didn't think muck about the airbag lol damn I m friggin old lol.. Buttons only it will be! ! :O
