2007 Chevy HHR LT - Windshield Leak?
I'm hearing water sloshing around when I turn....so I'm pretty sure it is clogged. Worked kicked my ass yesterday so I didn't even try to look for the hose again. Work is doing a pretty good job of repeating itself tonight.
Thanks for the additional info!
Thanks to Oldblue I was able to access the drain tube under the hood, behind the air filter box. I was able to get weed eater line in there but not the heavy duty clothesline. I didn't feel I got in very far. Water did come out...but nowhere near a gush of water. So I wasn't confident in my results. I did this yesterday. On my way to work last night I could still hear water sloshing around still. I haven't taken out the cabin filter yet but I have ordered one from RockAuto that should be here any day. I'm not sure how far the line should go up in the drain tube... I just don't think I got it all unblocked.
As Ronnie said in post #33 some water came out that drain hose, so if she was under her HHR she would be soaking wet! Now , you do raise a good suggestion for Ronnie.
Ronnie did you check the coolant level at the cooling system overflow tank and under the coolant filler cap on the upper radiator hose?
