2007 Chevy HHR LT - Windshield Leak?
Old Aug 13, 2020 | 08:13 PM
  #41
Ok. Post #30 never happened in this endless thread.
Old Aug 13, 2020 | 09:04 PM
  #42
Oh, sorry, yes post #30, Ronnie is there a puddle of water that dripped out of tge hose, or was it after you poked the string trimmer line on up in there?
Old Aug 13, 2020 | 10:34 PM
  #43
I deleted the same question because I noticed a small detail in her post #29.
It's raining.
A puddle on the ground would make the diagnosis uncertain.
Old Aug 14, 2020 | 10:48 AM
  #44
The weather lately would be leaving massive puddles under the car for months now. Most people ask "what is the puddle under my car from"?
If there is a puddle then the problem is the heater core or something else.
Old Aug 14, 2020 | 11:41 AM
  #45
Ronnie's Avatar
Originally Posted by donbrew
Why is it not possible to just look under the car for a puddle of water?
Water sloshing around in the waterfall are sounds more like low coolant level.
Water did come out...but more like trickling. Not gushing out like I have seen in the videos. There was water on the ground at that point from what came out of the A.C. drain tube . I just feel like it's not unclogged in its entirety.
Old Aug 14, 2020 | 11:43 AM
  #46
Ronnie's Avatar
Originally Posted by Oldblue
As Ronnie said in post #33 some water came out that drain hose, so if she was under her HHR she would be soaking wet! Now , you do raise a good suggestion for Ronnie.
Ronnie did you check the coolant level at the cooling system overflow tank and under the coolant filler cap on the upper radiator hose?
I have not checked the coolant levels. It will be next I guess.
Old Aug 14, 2020 | 11:49 AM
  #47
Ronnie's Avatar
It was after I poked it with the trimmer line...a small amount of water came out.
Old Aug 14, 2020 | 11:53 AM
  #48
Ronnie's Avatar
It's raining.
On 08/09 it was raining...on 08/13 when I was able to get the trimmer line in the drain it was sunny and hot.
So the small puddle was not rain. I may be blonde but I am far from dumb.
Old Aug 14, 2020 | 11:55 AM
  #49
Ronnie's Avatar
The puddle came from the A.C. drain tube after I was able to get the trimmer line in AC drain tube somewhat.
Old Aug 14, 2020 | 12:16 PM
  #50
So, there was never a puddle under the car before the trimmer line?
My car takes about 10 minutes to drop a quart of water; very noticeable.
Go to the local parts store and get some AC vent cleaner like this, there are many others
