Oh, sorry, yes post #30, Ronnie is there a puddle of water that dripped out of tge hose, or was it after you poked the string trimmer line on up in there?
Why is it not possible to just look under the car for a puddle of water?
Water sloshing around in the waterfall are sounds more like low coolant level.
Water did come out...but more like trickling. Not gushing out like I have seen in the videos. There was water on the ground at that point from what came out of the A.C. drain tube . I just feel like it's not unclogged in its entirety.
Reason: Additional comment
As Ronnie said in post #33 some water came out that drain hose, so if she was under her HHR she would be soaking wet! Now , you do raise a good suggestion for Ronnie.
Ronnie did you check the coolant level at the cooling system overflow tank and under the coolant filler cap on the upper radiator hose?
I have not checked the coolant levels. It will be next I guess.
It was after I poked it with the trimmer line...a small amount of water came out.
So, there was never a puddle under the car before the trimmer line?
My car takes about 10 minutes to drop a quart of water; very noticeable.
Go to the local parts store and get some AC vent cleaner like this, there are many others
