Abs light
Old Sep 1, 2018 | 10:26 PM
Dena's Avatar
ABS light
Nope. That's not the way the system works. The stock speakers can go out one at a time. There is nothing that will "shut them all down" unless you have a problem with the radio itself.
they're all off, so how can I tell if it's the speakers or the radio itself?
Old Sep 1, 2018 | 10:31 PM
Dena's Avatar
ABS light
Originally Posted by donbrew
It is possible if one actually shorts that the system will shut them down, But that rarely happens they just all die. The fact that the tweeters do work means that a shutdown is NOT the problem., just bad speakers.
oh brother, if that means all the speakers are bad that could cost a fortune to replace unless......I hit a junk yard, what do you think?
Old Sep 1, 2018 | 10:42 PM
Dena's Avatar
ABS light
Originally Posted by Oldblue
Check at your local parts palace, and check for loose harness at all four wheel hubs.
Thanks, I got someone coming pretty soon to check it all out so I'll mention that to him. Thanks again!
Old Sep 1, 2018 | 11:25 PM
The tweeters are wired in parrallel with the front door speakers, so if they are working and the door speakers are not the speakers are bad.
Why not go to Walmart/Autozone/advance/pepboys/ebay/crutchfield/bestbuy and get some speakers? Depending on your ear $10-$200 each. If you have a screwdriver and a putty knife you can do it. Lots of info at crutchfield.com and here in our how-to and AV sections.
Old Sep 1, 2018 | 11:56 PM
Dena's Avatar
ABS light
thanks alot, I'll do that
Old Sep 2, 2018 | 11:39 AM
Dena's Avatar
ABS light
I found out it's the amp that's bad on my stereo system.
Old Sep 2, 2018 | 01:27 PM
Then how do the tweeters work?; they are wired directly to the front door speakers, not a separate wire from the amp.
Old Sep 2, 2018 | 09:11 PM
Dena's Avatar
ABS light
[QUOTE=donbrew;851325]Then how do the tweeters work?; they are wired directly to the front door speakers, not a separate wire from the amp. Damn, now I'm even more confused, wish you wete in the neighborhood!
Old Sep 3, 2018 | 02:33 PM
I think speakers are your problem, and possibly the amp, but speakers are the most common culprit
Old Sep 3, 2018 | 06:50 PM
Dena's Avatar
ABS light
I'm going back to my thoughts from the beginning,, we've had problems with the driver's side door. Awhile ago it wouldn't open from the outside, it was fixed. Of course the panel was removed to do that. Days later the inside handle busted off, it's due to be replaced but in the meantime we have to open it from the outside. I really think the problem is in that door, whether it be the speaker or what, I think the problem is there. We have someone coming this week to check it out. Hopefully we'll get to the bottom of that. Going in the shop tomorrow to find out what's wrong with the ABS.
questionMARK
Oct 21, 2016 02:27 PM
ald
Jun 2, 2016 12:17 AM
rjdelapp
Jul 26, 2012 10:56 AM
helhedded
Mar 22, 2012 06:55 AM
matts
Dec 10, 2008 08:52 PM
