Battery went completly dead, now instrument cluster is not working
Old Jun 26, 2022 | 10:46 AM
  #41
Garyroe75's Avatar
Nope
Originally Posted by donbrew
Have you checked fuses #2 & #4 under hood and #7 & #16 on the BCM?
The GN/BK wire in the instrument panel connector is the GMLAN, the wire that carries all of the digital data. it goes to a splice location taped to the harness behind the BCM. If everthing else is working the problem is probably between the 2 points, the other wires in that splice go to the RCDLR, the PK3 sensor in the ignition switch, the SDM behind the gear shift and to the BCM pin #38 on the big blue BCM connector.
No power to those 4 while running. Now I feel stupiderester...
Old Jun 26, 2022 | 11:03 AM
  #42
#4 & #6 underhood should be hot always. That leads me to think either the battery wire to the fuse box is disconnected or the internal connections of the fuse box are bad.
If you separated the fuse box you should recheck the bolts. they need to be tightened way past what feels tight.
Old Jun 26, 2022 | 11:08 AM
  #43
Garyroe75's Avatar
Hmmm
new battery, power to the fusebox, replaced fusebox...
Gonna pull it and check pins. Unlikely to have same problem after the swap. Sprayed contact cleaner also.
Old Jun 26, 2022 | 11:13 AM
  #44
Figure another way that a fuse that is supposed to be connected directly to the battery is not getting power.
Old Jun 26, 2022 | 11:31 AM
  #45
Was it a brand new fuse block? Or what car did it come from?
Old Jun 26, 2022 | 11:43 AM
  #46
Garyroe75's Avatar
Good
From a running wreck I just scrapped, same year. Want I should grab another? Identical problem tells me its deeper....
Old Jun 26, 2022 | 11:44 AM
  #47
Garyroe75's Avatar
Not opposed to taking to dealer once I exhaust my options. I hate being a "parts changer"....
Old Jun 26, 2022 | 12:52 PM
  #48
Oddly enough, another member had the same problem and did post the solution to his. As I suggested earlier; crank down on the bolts in the fuse box past what you think is tight, until it clicks sounds like it broke.
https://www.chevyhhr.net/forums/prob...tarting-65434/
j67
Jul 14, 2020 08:16 PM
Tonyautrino
Feb 27, 2018 08:31 AM
drse
Mar 21, 2017 08:44 AM
elzorroadrian
Jun 26, 2016 06:54 PM
jeff schaffer
2.2L Performance Tech
Sep 8, 2013 01:50 AM
