Blinking Led wiring
I've merged the two threads maybe it will speed up a resolution.
I'm also scanning for a wire harness ...and found this
http://www.angelfire.com/co/ladyjarr.../HHRWiring.pdf
The red/black wire is a constant 12v power to the BCM.
Here is a schematic
http://2.bp.blogspot.com/-GFEkEZL8cB...ng+Diagram.gif
Disconnect the wire you tapped into it , check all fuses , replace burnt fuse, your HHR should now start!
Now do you have more information about this blinking alarm light you want to connect?
Is it just a decoy light that flashes to fool burglars ?
Your car does have a built in alarm from the factory, your key FOB controls it.
Here is a schematic
lorrimac79
Oct 10, 2012 09:13 AM
