Can of worms.
Old Feb 28, 2020 | 06:28 PM
I’ve sent a PM
Old Feb 29, 2020 | 09:36 AM
Zachary Morgan's Avatar
Air box was off when I took pics
The air flow sensor is hooked up to a different connector then the one coming off the fuel rail harness.
Old Feb 29, 2020 | 09:39 AM
But why not connected to the correct connection?
Have you tried connecting the MAF to the proper connection?
Originally Posted by donbrew
Does it run now? Just not good? Any codes? Does the wiring harness fit?
I think that the crankshaft sensor is on the back side on a 2.4 and the front on a 2.2.
I replaced the crankshaft sensor already but still not getting any RPM data on scan tool live data or cluster.
Old Feb 29, 2020 | 09:41 AM
I apparently have two connection to the air flow sensor then.... well that's confusing
Old Feb 29, 2020 | 09:42 AM
  #26
How could it if it’s not connected to the correct connection in the harness.
Old Feb 29, 2020 | 09:45 AM
  #27
Look next to the abs module in the picture, you'll see the sensor and second connection
Old Feb 29, 2020 | 10:51 AM
  #28
Donbrew, that red connector you've circled, are you sure that's for the MAF?
I seem to remember someone saying that they accidentally switched the connectors for the throttle body and something else, they both had the same connector.
Old Feb 29, 2020 | 11:30 AM
  #29
I am too confused to carry on.
Old Feb 29, 2020 | 01:13 PM
  #30
Here’s a few pictures of my 2.4 harnessing
