Clunking issue: Solved!
Old 03-22-2019, 10:10 AM
  #171
Oldblue is offline
Old 03-22-2019, 11:44 AM
  #172
Cat Man HHR's Avatar
Use Rockauto and use the 5% discount.
Cat Man HHR is offline
Old 03-22-2019, 11:52 AM
  #173
Oldblue is offline
Old 03-22-2019, 12:02 PM
  #174
Radco's Avatar
I work PT at a Parts Store so I do get a discount, Interesting seeing the parts in hand, Learning more about car parts,even though I can not fix it myself I like knowing what they are lol Is it a good idea to cnahge the sway bar links even though I really do not notice a issue, I figure since it will be up in the air for the struts /shocks labor will be a minor issue :) Sorry for the dumb question's, Planning on keeping my HHR for awhile ,but may go to one of my grandson's so I want it done right :)
Thanks again
Radco is offline
Old 03-22-2019, 02:06 PM
  #175
Buy Moog sway bar links (10"). Some people call them end links. Good part and they're greasible. Original ones (OEM) made a clunking noise that so many complained about.
Old 03-22-2019, 02:49 PM
  #176
If you are doing struts you must remove the top link nut; you are half way there already.
donbrew is offline
Old 03-22-2019, 02:50 PM
  #177
Yes, Moog K750012. They are the correct length for your HHR.
I undo the nut on the swaybar end then just leave the old link attached to the strut. Less busted knuckles!
Oldblue is offline
Old 07-22-2020, 04:15 PM
  #178
Sailor2's Avatar
Hello, reading these posts about front end links, I realized that the most current was from 2011. Anyway, several folks state that the 10" link should fit all HHR's, the OEM links I replaced were the longer length and checking with RockAuto the part number they show for my 2007 is also for the 10" link. I think mine need replacing again but in a quandary as to the size now. Any recommendations?
Sailor2 is offline
Old 07-22-2020, 04:35 PM
  #179
As I posted above , the 10 inch ones
Oldblue is offline
OldSchool57
18
05-01-2012 02:33 PM
jdjaa1959
02-03-2012 05:42 PM
kmcrae476
06-10-2011 08:54 PM
cosmic1
04-18-2011 09:47 PM
jerij
12-15-2005 06:31 PM
Quick Reply: Clunking issue: Solved!
