Dome light
Old Dec 19, 2016 | 01:21 PM
Here is the 2011 wiring diagram:
Old Dec 19, 2016 | 01:22 PM
chibearsfan4life's Avatar
so in my car i have two bulbs in each lens(one on each side). i turned on each one to make sure they worked.
i will try and post a pic to show it
here is the one i have in my car. this is not a pic of mine, this is a generic pic i found of the same one.
what amp should the interior light fuse be?
right now its 10amp
Old Dec 19, 2016 | 04:58 PM
10A is correct. Did you push the buttons? What about the cargo dome light?
Could be relay #32 on the BCM (Retained Accessory Power)
Old Dec 19, 2016 | 05:44 PM
On mine, only the center bulb of each come on for the dome. The 2 bulbs you are describing come on with the pushbuttons only, map lights independent of the dome light system. Of course, the third(cargo) light has only the center bulb, no pushbuttons.
Old Dec 19, 2016 | 08:56 PM
Does it come on when you open a door?
Old Dec 19, 2016 | 09:39 PM
bearsfan
Have you tried a test light or multi-meter ? All I see is mention of the fuses looking OK. You may stumble on a fix that way, but it would be easier using one of the above to check for power or ground connections.
Old Dec 19, 2016 | 11:12 PM
Originally Posted by chibearsfan4life
i took off all the lenses off to check. front and rear bulbs are good. the cargo doesnt have a bulb in it.
If you took off all the lenses, and you only have the 2 outer bulbs in each, then you need to install the center bulbs.
Old Dec 20, 2016 | 08:32 AM
H'mm, I guess the reason they don't work is they are not installed.
Some former owner took offense to the lights coming on when they opened the door.
Old Dec 21, 2016 | 03:18 PM
Smile
So after finding out on here that the dome light was seperate, i went out and checked, well what did you know, the dome light was missing its bulb. so i took out one of the map lights and put it where the dome light bulb should and it worked. so i will just need to get replacement bulbs .
Thanks to everyone for all for your help in fixing this problem.
fastsuv
"How To" Tutorial Library
77
Jul 28, 2020 10:57 PM
billdaly
Apr 30, 2008 08:02 PM
Velocity12
Feb 1, 2007 08:51 PM
bgnoz
Jul 29, 2006 12:31 PM
Skully
Mar 18, 2006 06:34 AM
