Dome light
so in my car i have two bulbs in each lens(one on each side). i turned on each one to make sure they worked.
i will try and post a pic to show it
here is the one i have in my car. this is not a pic of mine, this is a generic pic i found of the same one.
what amp should the interior light fuse be?
right now its 10amp
right now its 10amp
On mine, only the center bulb of each come on for the dome. The 2 bulbs you are describing come on with the pushbuttons only, map lights independent of the dome light system. Of course, the third(cargo) light has only the center bulb, no pushbuttons.
bearsfan
Have you tried a test light or multi-meter ? All I see is mention of the fuses looking OK. You may stumble on a fix that way, but it would be easier using one of the above to check for power or ground connections.
So after finding out on here that the dome light was seperate, i went out and checked, well what did you know, the dome light was missing its bulb. so i took out one of the map lights and put it where the dome light bulb should and it worked. so i will just need to get replacement bulbs .
Thanks to everyone for all for your help in fixing this problem.
fastsuv
"How To" Tutorial Library
77
Jul 28, 2020 10:57 PM
