Electrical Nightmare
If I understand correctly, neither the RAP, nor the lockout switch is to blame. The RAP relay only connects directly to the front windows, and the lockout only controls the rear windows.
The right side windows ground under the passenger seat, the left side windows ground under the driver seat. Messing with the ground under the passenger seat should not cause the driver side window to quit working.
My car is unplugged right now, so I can't test. Does RAP allow the rear windows to operate from their individual switches? I'm guessing not. This is 2009-2011 and 2008 SS only.
I'm about out of ideas. What happens if the master switch is completely disconnected, do any of the individual switches work then?
Here's that link Oldblue posted before. Read all of it. Especially post #12.
https://www.chevyhhr.net/forums/prob...ws-quit-53631/
Just to give you an idea of how to access the RAP relay.
Ohmed out the wires from the driver's control to each switch, no issues found.
Pulled the drivers seat. Found the grounds . They look like they would when the car was built , just like the passenger side.
Fuse under the hood good. Two fuses in BCM good.
Have power at all fuses.
None of the window switches operate any window.
Direct
Pulled the BCM. RAP is secure. Put the BCM back together.
Out of the box idea...
Have you checked to be sure the weatherstripping isn't stuck to the glass, preventing movement? I have seen this if the windows aren't cycled for months and the car's outside. Exactly the same symptoms. Tree pollen and crap gummed the rear windows on my Oldsmobile right up.
He has said if he hot wires each window motor they work.
pulled all the fuses, ohm check good
Power to fuse sockets
How do I get to the RAP relay to check it?
Checked and cleaned (because I was there) 2 grounds under the dash by drivers door pillar, and 2 under passanger seat.
Now the drivers window dosen't work either.
Back to square one.
How do I access the connector for the drivers door inside the dash/pillar ?
Back to square one.
