Electrical Nightmare
Old Jun 29, 2020 | 12:52 PM
  #81
GreyHHR#2009's Avatar
Found the U tube video Saturday . tried that . Did not make a difference so I put in the new set of 4 I bought just in case.
Old Jun 29, 2020 | 12:53 PM
  #82
The underhood fuse #36
https://www.google.ca/search?q=hhr+p...iw=375&bih=626
Old Jun 29, 2020 | 12:54 PM
  #83
Is there some way to rewire the power to all the switches at the same time?
Old Jun 29, 2020 | 12:55 PM
  #84
OLDBLUE:Fuse good and power to one side with fuse out.
Old Jun 29, 2020 | 01:20 PM
  #85
Then why the question to rewire? Try cleaning the switches in the drivers door.
  #86
Cat Man HHR's Avatar
Originally Posted by misfit of warren
OLDBLUE:Fuse good and power to one side.
If you have power to one side how come not the other ?
Or are you saying power is going thru the fuse ?
Old Jun 29, 2020 | 01:21 PM
  #87
Dirty switches
Old Jun 29, 2020 | 01:29 PM
  #88
Require ???
Cleaned all switches as previously stated and that made no difference. Bought OEM new switches and install them. No difference.
Old Jun 29, 2020 | 02:06 PM
  #89
IF you have power to all the needed locations, then the next step would be to check the ground circuit for the main window switch.
There should be one main ground wire to that switch. Check the continuity of that wire.
Old Jun 29, 2020 | 03:11 PM
  #90
You say you bought all four switches, watched a video on Saturday, installed all 4 (I assume you mean switches) you bought just in case.
Please verify, new or used switches? New GM OEM or afternoon market . If new then track down the ground wire as FMG states .
