Engine Revs at the touch of the pedal
Old Dec 4, 2022 | 09:45 PM
See post #7 for the codes.
Old Dec 4, 2022 | 10:02 PM
And repeated (quoted) in post #18
Old Dec 4, 2022 | 10:12 PM
greg8453's Avatar
You guys make these threads into a novel in short order.
Old Dec 4, 2022 | 10:33 PM
Not a novel, a conversation.
Old Dec 5, 2022 | 08:14 AM
Scrolling is so hard.
Old Dec 5, 2022 | 09:15 AM
  #26
Causes for this P0757 transmission code may include:
Insufficient fluid level
Dirty or contaminated fluid
Dirty or clogged transmission filter
Defective transmission valve body
Restricted hydraulic passages
Transmission has internal failure
Faulty shift solenoid
Corroded or damaged connector
Faulty or damaged wiring
Common repairs for this code
Changing the fluid and filter
Repair or replace a faulty shift solenoid
Repair or replace defective transmission valve body
Transmission flush to clean passages
Cleaning corrosion from connectors
Repairing or replacing wiring
Yes it could be as simple as checking the transmission fluid level.
Old Dec 6, 2022 | 09:08 AM
  #27
Is the OP’s car a SS or not ???
This thread is in the HHR SS forum but post #1 says it’s a 2011.
Old Dec 6, 2022 | 09:24 AM
  #28
PulpFriction's Avatar
OP profile says 2011. Probably just started in the wrong place due to a search hit.
This is a serious safety issue. Get it to a really good mechanic yesterday.
Old Dec 6, 2022 | 10:59 AM
  #29
Moved out of the SS area.
antiasinine
Oct 7, 2018 11:47 PM
mclc126
Feb 23, 2015 01:27 PM
tamu15
Feb 8, 2014 07:01 PM
menance
Dec 22, 2010 06:14 PM
beachbum1970
Mar 25, 2009 08:46 PM
